Automatically switch off your internal screen if an external screen is connected
This can be easily done by running a small background script (started automatically on startup (log in).
What it does
The script will automatically switch off your internal screen if your TV (or any other secundary screen) is connected. If you only want it to work for a specific external screen, please mention.
The script
#!/usr/bin/env python3
import subprocess
import time
# --- set your internal screen below (the example is my primary screen)
internal = "DVI-I-1"
# don't change anything below
scr_info1 = 0
while True:
time.sleep(4)
# read the current screen setup from xrandr
get_screens = subprocess.check_output("xrandr").decode("utf-8").splitlines()
scr_data = [l for l in get_screens if " connected " in l]
# count the number of connected screens
scr_info2 = len(scr_data)
# if the number of connected screens changes,
# switch off the internal one if there are two screens
if scr_info2 != scr_info1:
if scr_info2 == 2:
ext = [s.split()[0] for s in scr_data if not internal in s][0]
subprocess.Popen(["xrandr", "--output", internal, "--off", "--output", ext, "--auto"])
scr_info1 = scr_info2
How to setup
- Copy the script below into an empty file, save it as
switch_screens.py
- In the head section of your script, set the name of your internal screen. To find out, open a terminal window and run the command
xrandr (no external screen connected) The line with "connected" in it shows the name of your screen in the first string, looking like: VGA-1 or something like that.
Test- run it by opening a terminal window and typ the command:
python3 /path/to/switch_screens.py
While the script runs, connect your TV, wait for you internal screen to switch of and disconnect again.
If all works fine, add the command below to Startup Applications: open Dash > Startup Applications > Add. Add the command:
/bin/bash -c "sleep 15 && python3 /path/to/switch_screens.py"
Log out and back in. Now your internal screen is switched off automatically if an external screen is connected.
