I have a problem since the last update: Nautilus mysteriously doesn't start properly. I see it is a systems wide problem, i.e. affecting all the users on my host. Nevertheless, I have tried:
  1. clean ~/.gconf folder
  2. clean ~/.config folder
But nothing seems to cure the issue.
As a temporary workaround I can:
killall nautilus
nautilus -q
nautilus
Then wait for a few tens of seconds, no error displayed, and nautilus starts.
In the process I get:
andy@Andy-HyperTop14$ nautilus -q
Initializing nautilus-image-converter extension
sys:1: Warning: Source ID 273 was not found when attempting to remove it
sys:1: Warning: Source ID 274 was not found when attempting to remove it
sys:1: Warning: Source ID 275 was not found when attempting to remove it
I don't understand this output.
This seems to be a common problem flagged in: How to restart nautilus without logging out?
Question 1 Where are the Nautilus related errors logged? I have looked in
/var/log
But nothing can be connected to Nautilus from there.
Question 2 Is there a way to run the tool in "debug mode"?
Thanks in advance for your help.
Andrea Borga
  • 1,100
Here is a solution I found from the GNOME website. Simply set the environmental variables before launching nautilus, i.e.:
G_DEBUG="all" NAUTILUS_DEBUG="All" nautilus
Logs can be captured from the terminal output.
