I try to use an MicroSD card containing a chroot environment which I can break, e.g. by installing software, without damaging the OS on my bq Aquaris E4.5 Ubuntu Edition, however I can not let the filesystem being auto-mounted and use the chroot at the same time.
  • ext4 and similiar filesystems do not get mounted by ciborium → by default the sd card is not mounted when using ext4, an error is indicated and I am asked to format the disk as vfat
  • vfat does not support the execute permission → I cannot run programs of the chroot when the chroot is saved on a vfat partition
  • To me there is no known way to start a script automatically on startup (I have found this while searching for an answer) without changing the file-system which is by default intentionally mounted as read-only → I can not easily create a mount script executed on startup
So I wonder whether there is a way to auto-mount an MicroSD-card which can be used to store an chroot without modifying the write-protected parts of the phone.
I have ext2 partition on my sd card and I want automount for this partition. Here is my solution for Ubuntu Touch BQ Aquaris m10.
At first, we make a system partition writable:
sudo touch /userdata/.writable_image
After doing this system will reboot. Then, we edit /lib/init/fstab:
sudo nano /lib/init/fstab
and add this string in bottom:
/dev/mmcblk1p2  /home/phablet/mnt/sd      ext2            defaults,noatime,nodiratime,errors=remount-ro 0 2
Then, we make system partition read-only again:
sudo rm /userdata/.writable_image
And rebooting:
sudo shutdown -r now
It works!
Vladimir
  • 207
