How can I remove one, or multiple segments from a webm video using avconv (without reencoding)?
whtyger
  • 5,900
  • 36
  • 48
To remove a single segment of a webm file you can use the standard method of seeking to a particular section of your file and then specifying a time duration to extract.
For example the following will take a section from 1 minute into a file and copy 60 seconds following this into another file:
avconv -ss 00:01:00 -i video.webm -t 60 -c copy cut.webm
To extract multiple segments of a webm file you can use avconv's basic stream segmenter. For example the following will split a webm video into 60 second segments and generate a playlist file as well:
avconv -i test.webm -c copy \
       -f segment -segment_time 60 -segment_list list.pls \
       output%03d.webm
A few choices to make with the segmenter but the above examples covers the basics...
andrew.46
  • 39,359
