I've setup a server at home with Ubuntu server 14.04 LTS to develop and experiment on for our Magento webshop. The server itself runs fine when contacted from the internal network. I got magento to load under 1s so everything runs fine.
However now i switch a lot between locations and would like to keep to work on the installation form an external point.
When i call the server by IP nothing loads... when i remove the CMS and place a static HTML page it loads fine. However when i put the CMS (magento store in this case) back and try to reach it nothing works.
I had Apache2 configured to listen to 2417 instead of 80 (my router blocks it), and setup a port forward.
After some googling i cannot come up with a solution and hope you guys can steer me in the right direction :)
If i have left out needed information please ask and i'll fill in (Kind of new to the external home server setup... )
UPDATE: I've just performed a clean install to start from scratch, Apache2 has been configured to listen to 2417.
Firewal is inactive
Do i need to set other components like MySQL to listen to another port also to make te CMS accessible from the outside?
Thanks in advance! Kind regards, NIck
