I have downloaded and installed emacs from the homepage and now want to unistall and reinstall it. When i do remove purge or autoremove the emacs icon is still to see at the sidebar left, but the terminal says that package emacs is not installed so not removed. How can i completely unistall emacs and all related data?
Asked
Active
Viewed 852 times
If you installed from Emacs website it means you installed by the sources, right? When installing from source usually people uninstall by runnning:
sudo make uninstall
To avoid this kind of problems in the future start using the CheckInstall package which keeps track of all files installed by a "make install" or equivalent, creates a Debian package with those files, and adds it to the installed packages database, allowing for easy package removal or distribution.
To remove the icon from Dash you can follow the instructions from this another AskUbuntu question:
Remove the files
~/.local/share/applications/Emacs.desktopand/usr/share/applications/Emacs.desktopif they exist.
Alexandro de Oliveira
- 141
- 1
- 7
