I would like to install both packages libsigc++-2.0-0c2a and libsigc++-2.0-0v5 at the same time, in order to run certain software.
Apparently, however, the packages are conflicting and
sudo apt-get install libsigc++-2.0-0v5 libsigc++-2.0-0c2a
results in
The following packages have unmet dependencies.
libsigc++-2.0-0v5 : Conflicts: libsigc++-2.0-0c2a but 2.2.10-0.2ubuntu2 is to be installed
Is there a common strategy to approach such situations? Shouldn't the "Version numbering" solution apply here?
Martin R.
  • 446
Problem
I agree with MichaelW that it contains same lib file with same version. However, the error you got is not related that but it is packages version conflict declared in one of the packages:
$ dpkg --info Downloads/libsigc++-2.0-0v5_2.4.1-2_amd64.deb
 Replaces: libsigc++-2.0-0c2a
If those lines are removed, we got the error related same files overwriting, similar to this one:
Unpacking libjline-java (from .../libjline-java_1.0-1_all.deb) ...
dpkg: error processing /var/cache/apt/archives/libjline-java_1.0-1_all.deb (--unpack):
 trying to overwrite '/usr/share/java/jline.jar', which is also in package scala 2.9.2-400
Error Source: dpkg error: "trying to overwrite file, which is also in..."
As they are compiled to same version, it is not possible to put them together neither changing name manually will help. Tools on repository had already compiled to use libsigc-2.0.so.0.
Solution
Here is an easy solution with test case.
Test case:
I looked for package the depends on same library using:
$ apt-cache rdepends libsigc++-2.0-0v5
  libatkmm-1.6-1v5
  inkscape
  gparted
  gnome-system-monitor
  aptitude
Verify that the contained binary really depends on it, using:
$ dpkg -L gnome-system-monitor | grep /bin/
/usr/bin/gnome-system-monitor
$ ldd `which gnome-system-monitor` | grep libsigc
    libsigc-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libsigc-2.0.so.0 (0x00007f9491bec000)
Instructions:
  1. Create a folder to contain the external shared lib (the other version you are unable to install), example:
    mkdir ~/Desktop/sand_box/local_so_lib_test
  2. Extract the library fro the package
    $ dpkg-deb --extract ~/Downloads/libsigc++-2.0-0c2a_2.2.10-0ubuntu2_amd64.deb /tmp/libsigc
    $ cp -a /tmp/libsigc/usr/lib/x86_64-linux-gnu/* ~/Desktop/sand_box/local_so_lib_test
    $ ls -l
    total 20
    lrwxrwxrwx 1 sneetsher sneetsher    20 Dec 12  2011 libsigc-2.0.so.0 -> libsigc-2.0.so.0.0.0
    -rw-r--r-- 1 sneetsher sneetsher 18488 Dec 12  2011 libsigc-2.0.so.0.0.0
  3. Start the special dependent tools, by setting LD_LIBRARY_PATH
    $ LD_LIBRARY_PATH=~/Desktop/sand_box/local_so_lib_test gnome-system-monitor
Check:
$ LD_LIBRARY_PATH=~/Desktop/sand_box/local_so_lib_test ldd /usr/bin/gnome-system-monitor | grep libsigc
    libsigc-2.0.so.0 => /home/sneetsher/Desktop/sand_box/local_so_lib_test/libsigc-2.0.so.0 (0x00007fabbe960000)
$ LD_LIBRARY_PATH=~/Desktop/sand_box/local_so_lib_test gnome-system-monitor &
$ lsof -c "gnome-system-mo" | grep libsigc
gnome-sys 28655 sneetsher  mem       REG                8,5    18488  2752572 /home/sneetsher/Desktop/sand_box/local_so_lib_test/libsigc-2.0.so.0.0.0
user.dz
  • 49,176
Both packages contain the same files:
  • /usr/lib/x86_64-linux-gnu/libsigc-2.0.so.0
  • /usr/lib/x86_64-linux-gnu/libsigc-2.0.so.0.0.0
You can find this in the package details searching in the Ubuntu packages: http://packages.ubuntu.com/
e.g. http://packages.ubuntu.com/wily/amd64/libsigc++-2.0-0v5/filelist http://packages.ubuntu.com/precise/amd64/libsigc++-2.0-0c2a/filelist
So the confilct is caused by the same files in the packages. What should the system do now? Since it can't decide it, it displays the conflict.
Michael W
  • 213
try sudo apt-get build-dep libsigc++-2.0-0v5 libsigc++-2.0-0c2a
kpie
  • 275
