I'm using an Ubuntu 14.04 system and I'm trying to install skype on my system. I followed the steps given in the following link to install here. I first tried installing the .deb package from their site and Software Center says it needs libqt4-dev:i386 and stops download. I tried to install directly from the software center and it gives an unmet dependencies error with skype-bin package. I tried to install the missing packages using apt-get but that didn't work either.
How do I fix this so I can get Skype to work properly?
Edit#1: I tried the following code:
sudo apt-get install -f sudo dpkg --add-architecture i386 sudo apt-get update wget -O skype-install.deb http://www.skype.com/go/getskype-linux-deb sudo dpkg -i skype-install.deb
Skpe gets installed but it shows there were some during installation.(Deosn't list the errors though). I get this message:
Errors were encountered while processing: skype The skype logo shows up in the launcher but it doesn't run. I tried running it from terminal and got this error:
skype: error while loading shared libraries: libXv.so.1: cannot open shared object file: No such file or directory
SY_13
  • 486
  • 22
Prior to version Skype 4.3, it was available as binary file, so that users can only download the binary file from it’s official and install it manually. But, as of version 4.3, Skype is available in the Canonical Partners repository.
To enable the Canonical Partners repository, go to Software & Updates from Unity dash. Navigate to Other Software tab, and enable Canonical Partners repository.
Click Close, and Reload buttons to update the cache. Then, type the following command to install Skype.
sudo apt-get install skype
Edit
According to http://packages.ubuntu.com/ Edit /etc/apt/sources.list
Add the following line
deb http://security.ubuntu.com/ubuntu trusty-security main
Save and update Then run
sudo apt-get install libxss1:i386 libqtcore4:i386 libqt4-dbus:i386 libqtgui4:i386
Finally run
GAD3R
  • 3,748
Try to start skype from terminal like this:
LD_PRELOAD=/usr/lib/i386-linux-gnu/libXv.so.1 skype
