I have a 5 year old Toshiba Satellite L745. I wanted to install Ubuntu on it. It only has legacy BIOS and no UEFI. When I attempt to boot from a flash drive (I tested 2 flash drives and both worked on my desktop with UEFI) I received the error: "Missing operating system". I've installed it several different ways (ddrescue, Startup Disk Creator, Gnome Disk Utility, Unetbootin) and it won't work. The only thing I can get to boot is MATE and that is what is on it right now, but if I could, I'd prefer Ubuntu or Kubuntu. I've done a lot of googling and still can't seem to find the answer, so if anyone has any ideas, it would be appreciated
Edit:
It seems that Ubuntu 15.10 has no legacy BIOS support? Because the result of fdisk -l labels it as an "EFI system". The output for the flash drive:
`Device Start End Sectors Size Type
/dev/sdc1 2048 15628287 15626240 7.5G EFI System`
Update: I've made progress(?). Using the Startup Disk Creator on Ubuntu, I managed to get the following message when trying to boot:
SYSLINUX 6.03 EDD Copyright(etc...)
Boot error
Another update: I figured it out. I posted an answer down below. I can't accept it for 22 hours though.
