I recently installed LXDE in Ubuntu 11.10, so that I can choose it at the login screen, but I've since noticed that there's no compose key (since I enabled it in Gnome Shell and Unity) so I was wondering how to enable a compose key?
Thanks for any help :)
muru
  • 207,228
setxkbmap -option "compose:caps" for CapsLock
setxkbmap -option "compose:ralt" for right alt =)
fetsh
  • 266
To set the compose key
sudo leafpad /etc/default/keyboard
edit XKBOPTIONS to like this
XKBOPTIONS="compose:Shift+AltGr"
To get a list of available keys:
grep compose /usr/share/X11/xkb/rules/xorg.lst
Reboot for the change to be applied or
setxkbmap -option "compose:Shift+AltGr"
To check if the option was set correctly
setxkbmap -print -verbose 10
Example:
press Shift then AltGr and release then click on "o c" to obtain ©.
Additional reading
shantiq
  • 607
You can check if the keyscan code on your keyboard same as default setting. Did you check if you can do the compose by selecting predefined keyboard with Compose key?
tomchiukc
  • 248
For iBus, you can use
setxkbmap -option "lv3:ralt_switch_multikey"
This is defined in /usr/share/X11/xkb/rules/ as "Right Alt [for 3rd level], Shift+Right Alt key is Compose"
This is also included when you select the gb layout:
setxkbmap -layout gb
