Need help in getting the right mouse click to work on a HP mini 210-1015TU when using the touchpad.
If I plug in a USB mouse, both left click and right click function as normal. Using the touchpad however I can only get the left click to work. Attempting to right click gives the result expected from a left click. As per some comments on a forum I added a file 11-touchpad.conf to /usr/share/X11/xorg.conf.d. I can provide further details if required.
This made touchpad operation noticeably smoother but the problem with the right mouse click remains. Not a hardware problem as right clicked worked with 10.04 and still works with Windows 7 starter. 10.10 installed using wubi.
Jorge Castro
  • 73,717
5 Answers5
You may also be interested in installing gpointing-device-settings package, which will provide more configuration options for your touchpad.
sudo apt-get install gpointing-device-settings
Once installed you find it under System -> Preferences -> Pointing Devices.
Zanna
  • 72,312
MagicFab
  • 1,356
is that i'm going to input:
sudo su (Enter your password)
echo options psmouse proto=exps > /etc/modprobe.d/psmouse.modprobe
reboot
p/s: since i'm a newbie, i need to confirm the command to solve my problem at hp mini 210-1073TU.
Jorge Castro
  • 73,717
I've found a workaround which worked with my Lenovo Edge E320 with a clickpad.
Just create /usr/share/X11/xorg.conf.d/51.clickpad.conf and paste the following content:
Section "InputClass"
Identifier "Default clickpad buttons"
MatchDriver "synaptics"
Option "SoftButtonAreas" "50% 0 82% 0 0 0 0 0"
EndSection
After a restart of the xserver the clickpad worked just fine and the mulitouch features are now operational.
Source: Ubuntuusers.de
sedesc
try TAPPING the lower right corner of the touchpad instead of clicking the button
marto
  • 1,431
EndSection*
This works great on an HP pavilion 15 p132nd, for anyone experiencing a rightclick problem on this system. After adding the new file and the lines as in the post, just restart the system to make it work.
TheSchwa
  • 3,860
