I'm a PHP developer and I'm using SublimeText editor for PHP coding on my machine that runs on Ubuntu Linux 12.04 LTS(64-bit) operating system.
I don't have installed any software related to Java(like jdk, jre, etc.)
Now I want to install and use Eclipse Mars for AngularJS coding.
How should I install it and run it?
Please provide me step by step instructions for the same. If there are any command which I can execute from the terminal please provide me the same.
Thanks.
PHPLover
  • 1,807
Before installing eclipse you need to install java , you can either install JRE or JDK .
sudo apt-get install openjdk-7-jre
or
If you are going to use eclipse for java development, then you can install JDK
sudo apt-get install openjdk-7-jdk
Download the latest eclipse package from here http://www.eclipse.org/downloads/?osType=linux
move the package to the /opt directory
sudo mv eclipse-SDK-4.2.2-linux-gtk.tar.gz /opt/
Unzip the package by typing the below command
cd /opt
sudo tar -xvf eclipse-SDK-4.2.2-linux-gtk.tar.gz
muru
  • 207,228
