I'm trying to install Landscape OpenStack Autopilot following this tutorial http://www.ubuntu.com/download/cloud/install-openstack-with-autopilot.
My distribution is Ubuntu 14.04.4 LTS server, I have updated/upgraded the packages before the installation of MAAS.
I have 5 nodes in my setup, I have a gigabit connection, and I believe MAAS is correctly configured. I can deploy a node outside the installer (Landscape Autopilot), the node can reach the Internet, ping google.com, and nslookup works.
I thought this was a timeout issue, so I increases the timeout of /usr/share/openstack/cloudinstall/controllers/install/multi.py file to 600 but this didn't resolve my issue.
I installed the package "juju" before launching installation. I'm getting stuck during installation:
    [INFO: 02-17 09:13:07, openstack-install:227] Starting OpenStack Installer v0.99.27
[INFO: 02-17 09:13:07, openstack-install:228] Start command: ['/usr/bin/openstack-install']
[INFO: 02-17 09:13:07, openstack-install:239] Creating juju directories: /home/dylan/.cloud-install/juju
[INFO: 02-17 09:13:08, openstack-install:295] Running Liberty release
[INFO: 02-17 09:13:17, installbase.py:132] Performing a OpenStack Autopilot install
[INFO: 02-17 09:13:17, utils.py:771] pollinate: sudo su - -c 'pollinate -q -r --curl-opts "-k --user-agent uoi/182e63ab-487b-4662-a101-cd320ac40a23/IL"'
[DEBUG: 02-17 09:14:10, landscape.py:74] Existing MAAS defined, doing a LDS installation with existing MAAS.
[DEBUG: 02-17 09:14:55, multi.py:127] Bootstrapping Juju: JUJU_HOME=/home/dylan/.cloud-install/juju juju  bootstrap
[DEBUG: 02-17 09:27:30, multi.py:165] Finished MAAS step, now deploying Landscape.
[DEBUG: 02-17 09:43:13, multi.py:391] Running landscape configure: /usr/share/openstack/bin/configure-landscape --admin-email dlndaubie04@gmail.com --admin-name dylan --system-email dlndaubie04@gmail.com --maas-host 10.10.24.101
[INFO: 02-17 09:43:15, utils.py:771] pollinate: sudo su - -c 'pollinate -q -r --curl-opts "-k --user-agent uoi/182e63ab-487b-4662-a101-cd320ac40a23/ET"'
[ERROR: 02-17 09:43:16, multi.py:397] Problem with configuring Landscape: {'output': '', 'err': 'Traceback (most recent call last):\n  File "/usr/share/openstack/bin/configure-landscape", line 209, in <module>\n    main()\n  File "/usr/share/openstack/bin/configure-landscape", line 202, in main\n    system_email=args.system_email)\n  File "/usr/share/openstack/bin/configure-landscape", line 173, in register_new_user\n    \'https://%s/api/\' % host)\n  File "/usr/share/openstack/bin/configure-landscape", line 126, in run_query\n    assert r.status_code == 200\nAssertionError\n', 'status': 1}.
[ERROR: 02-17 09:43:16, gui.py:267] A fatal error has occurred: Error configuring Landscape.
[DEBUG: 02-17 09:43:16, error.py:35] showing error view for: Error configuring Landscape.
[ERROR: 02-17 09:43:24, ev.py:130] Exception in ev.run():
  File "/usr/share/openstack/cloudinstall/ev.py", line 128, in run
    self.loop.run()
  File "/usr/lib/python3/dist-packages/urwid/main_loop.py", line 278, in run
    self._run()
  File "/usr/lib/python3/dist-packages/urwid/main_loop.py", line 376, in _run
    self.event_loop.run()
  File "/usr/lib/python3/dist-packages/urwid/main_loop.py", line 1326, in run
    self._loop.run_forever()
  File "/usr/lib/python3.4/asyncio/base_events.py", line 276, in run_forever
    self._run_once()
  File "/usr/lib/python3.4/asyncio/base_events.py", line 1172, in _run_once
    handle._run()
  File "/usr/lib/python3.4/asyncio/events.py", line 120, in _run
    self._callback(*self._args)
  File "/usr/lib/python3/dist-packages/urwid/raw_display.py", line 393, in <lambda>
    event_loop, callback, self.get_available_raw_input())
  File "/usr/lib/python3/dist-packages/urwid/raw_display.py", line 493, in parse_input
    callback(processed, processed_codes)
  File "/usr/lib/python3/dist-packages/urwid/main_loop.py", line 403, in _update
    self.process_input(keys)
  File "/usr/lib/python3/dist-packages/urwid/main_loop.py", line 503, in process_input
    k = self._topmost_widget.keypress(self.screen_size, k)
  File "/usr/share/openstack/cloudinstall/gui.py", line 136, in keypress
    return super().keypress(size, key)
  File "/usr/lib/python3/dist-packages/urwid/container.py", line 1128, in keypress
    return self.body.keypress( (maxcol, remaining), key )
  File "/usr/lib/python3/dist-packages/urwid/decoration.py", line 836, in keypress
    return self._original_widget.keypress((maxcol,), key)
  File "/usr/lib/python3/dist-packages/urwid/container.py", line 1587, in keypress
    key = self.focus.keypress(tsize, key)
  File "/usr/lib/python3/dist-packages/urwid/decoration.py", line 621, in keypress
    return self._original_widget.keypress(maxvals, key)
  File "/usr/lib/python3/dist-packages/urwid/wimp.py", line 535, in keypress
    self._emit('click')
  File "/usr/lib/python3/dist-packages/urwid/widget.py", line 463, in _emit
    signals.emit_signal(self, name, self, *args)
  File "/usr/lib/python3/dist-packages/urwid/signals.py", line 264, in emit
    result |= self._call_callback(callback, user_arg, user_args, args)
  File "/usr/lib/python3/dist-packages/urwid/signals.py", line 294, in _call_callback
    return bool(callback(*args_to_pass))
  File "/usr/share/openstack/cloudinstall/ui/views/error.py", line 66, in cancel
    raise SystemExit("Install exited because of error.")
SystemExit: Install exited because of error.
[DEBUG: 02-17 09:43:24, utils.py:59] Juju Version: 1.25.3-trusty-amd64
[INFO: 02-17 09:43:24, utils.py:61] Cleanup, saving latest config object.
Could someone help me to resolve my issue? Thanks in advance.
Byte Commander
  • 110,243
I can't help much with that openstack-install command, but something you could try, since you have MAAS already, is install Landscape on your own using juju:
https://help.landscape.canonical.com/LDS/JujuDeployment15.11
After you have configured juju to use MAAS:
https://jujucharms.com/docs/stable/config-maas
Use the landscape-maas-dense bundle. That will take one node from your MAAS to install all the landscape services.
Run juju status periodically to watch the deployment progress, and also keep an eye on the output of juju debug-log.
Once things are quiet there, hit the haproxy IP (you can get that from the juju status output) and follow the instructions to register.
Finally, once in the Landscape UI, go to the openstack tab and configure your cloud.
