is there any way to create a ubuntu live disk that includes all apps in my pc? i installed a lot of apps & gnome 3.2 on my ubuntu 11.10 & i want to share them with my friends on a disk that is live & able to install my distro on their PCs. do you have any idea?
arman
  • 213
None of the previous answers mention bootcd, that seems to correspond exactly to your question. Nevertheless, I never tried it.
This is the package description:
 Build an image of your running Debian System with the command bootcdwrite.
 You can also build a bootcd ISO image via NFS on a remote System.
 When you run your system from CD you do not need any disks. All
 changes will be done in ram. To reuse this changes at next boot time
 you can save them on FLOPPY with the command bootcdflopcp. If booting
 from your CD-drive is not supported, booting from FLOPPY is possible.
 It is possible to install a new system from the running CD with the
 command bootcd2disk. Bootcd2disk can also find a target disk, format
 it and make it bootable automatically. Bootcd also supports lilo,
 grub, initrd, udev, lvm, transparent-compression ISO 9660 fs and
 syslinux/isolinux. The included FAQ describes how bootcd can do
 online or offline backups of other Linux distributions, resulting
 in restore-bootcds. The bootcdbackupwizard helps to create online
 backups.
enzotib
  • 96,093
