I'm a new user of linux environment. I'm using ubuntu 11.10 and a MTS Mblaze USB modem. I have installed it correctly and it was working good at first but when I restarted my system then I was unable to connect my Modem again. Whenever I want click on that MTS connection, a message prompts up "Modem Network Disconnected. You are now offline." Please help to get me out of this problem.
Thanks & Regards.
david6
  • 14,528
  • 38
  • 46
Digvi
  • 51
A bug report is already created for this problem. It includes a work around also which may work for you. Check https://bugs.launchpad.net/bugs/868034.
Indika K
  • 121
check your modem manufacturer for example i have huwai E1550
make change to your "usb_modeswitch.conf" edit the file byyping this to terminal
sudo gedit /lib/udev/rules.d/40-usb_modeswitch.rules
to disable the rule place a # at start of the line , example
Quote:
# Huawei E1550
 ATTRS{idVendor}=="12d1", ATTRS{idProduct}=="1003", RUN+="usb_modeswitch '%b/%k'"
put a extra # in the front of line ATTRS(idVender)...........
# Huawei E1550
# ATTRS{idVendor}=="12d1", ATTRS{idProduct}=="1003", RUN+="usb_modeswitch '%b/%k'"
save this file and then restart
hope this will work because this worked for me . good luck
paru38
  • 684
You can try this command from a terminal:
sudo killall modem-manager
The problem seems to be the network daemon's inability to detect the modem settings...aggravated by its lack of real time operability.You could just disconnect it, wait then reconnect it and IF THE NETWORK HAS BEEN RECOGNIZED connect with no trouble at all. If not then you have to set up wvdial using appropriate settings to work(However,Doing so rendered network manager unable to recognize my connection and thus ALL applications were connected EXCEPT SOFTWARE CENTER which relied on identification by network daemon)SETTINGS FOR MTS INDIA;
[Dialer cdma]
Stupid Mode = 1
Inherits = Modem0
Password = mts
Username = internet@internet.mtsindia.in
Phone = #777
[Modem0]
Init1 = ATZ
SetVolume = 0
Modem = /dev/ttyUSB0
Baud = 115200
FlowControl = Hardware (CRTSCTS)
Dial Command = ATDT
Just replace settings in wvdial conf file and then...
hmayag
  • 2,266
  • 22
  • 24
Karthik
