I need to run a apache server locally in order to use the program labelme. However I'm not able to do it.
There is a description saying that I need to place my folder containing "index.html" inside /var/www/html.
However I need to run the website located in the local folder ~/libs/labelme.
I also followed this instruction from similar askubuntu-question. But it doesn't work for me. The browser just displays nothing when I try to reach that project-page.
I'm a novice in apache, so I don't even know if the problem lies with the way I configured apache or if the problem comes from labelme.
Any help would be appreciated
mcExchange
  • 3,398
Found some better documented version of the labelme code with better documentation. These is the full list of options that one needs to make the apache server run correctly (modify /etc/apache2/apache2.conf)
   <Directory "/var/www/LabelMeAnnotationTool">
       Options Indexes FollowSymLinks MultiViews Includes ExecCGI
       AddHandler cgi-script .cgi
       AllowOverride all
       Require all granted
       AddType text/html .shtml
       AddOutputFilter INCLUDES .shtml
       DirectoryIndex index.shtml
    </Directory>
mcExchange
  • 3,398
cd /etc/apache2/sites-available/
nano 000-default.conf
search for DocumentRoot /var/www/html (ctrl+w type /var/www/html)
replace /var/www/html with /home/labelme move lableme to /home/ directory
save the file 000-default.conf (ctrl+x and the y > enter)
edit /etc/apache2/apache2.conf file
add below lines after:
<Directory /home/labelme/>
        AllowOverride None
        Require all granted
</Directory>
restart apache2 web server:
service apache2 restart
And enter below URL into your browser
http://127.0.0.1/ or http://localhost/
OR
