this is the error im getting
Error mounting /dev/sda5 at /media/ubuntu/FILES: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=999,gid=999" "/dev/sda5" "/media/ubuntu/FILES"' exited with non-zero exit status 13: $MFTMirr does not match $MFT (record 0).
Failed to mount '/dev/sda5': Input/output error
NTFS is either inconsistent, or there is a hardware fault, or it's a
SoftRAID/FakeRAID hardware. In the first case run chkdsk /f on Windows
then reboot into Windows twice. The usage of the /f parameter is very
important! If the device is a SoftRAID/FakeRAID then first activate
it and mount a different device under the /dev/mapper/ directory, (e.g.
/dev/mapper/nvidia_eahaabcc1). Please see the 'dmraid' documentation
for more details.
Btw, I'm having trouble format my pc lately I'm getting an error from windows installer when i try to format the windows partition, this one I'm trying to access it's vital to me, cause everything I have is there... it maybe a problem with my HD? Tnx!
EDIT: just did this to try to fix it but now i cant even see it here anymore
ubuntu@ubuntu:~$ sudo ntfsfix /dev/sda5
Mounting volume... $MFTMirr does not match $MFT (record 0).
FAILED
Attempting to correct errors...
Processing $MFT and $MFTMirr...
Reading $MFT... OK
Reading $MFTMirr... OK
Comparing $MFTMirr to $MFT... FAILED
Correcting differences in $MFTMirr record 0...OK
Correcting differences in $MFTMirr record 1...OK
Correcting differences in $MFTMirr record 2...OK
Correcting differences in $MFTMirr record 3...OK
Processing of $MFT and $MFTMirr completed successfully.
Setting required flags on partition... OK
Going to empty the journal ($LogFile)... OK
Failed to access '/dev/sda5': No such file or directory
Error opening '/dev/sda5': No such file or directory
Remount failed: No such file or directory*
TNX!
muru
  • 207,228
Firstly - BACKUP your USB drive.
Any command (like I am about to share) - possibly will corrupt/loose your data. So PLEASE bask the device up.
Assuming that you have BACKED it up
ntfsfix /dev/hda5
This is assuming that you have installed ntfs-3g so you refer to that device.
I can see you tried the command I mentioned - but the Error messages do not help....
To show which drive is mounted do a
sudo fdisk -l
And assuming that your USB Drive is there... change the ntfsfix
Tim Seed
  • 121
