13
I have a .sh script that downloads a photo from Japanese satellite's server and sets it as a background picture. I've put it into startup list, but how do I run it every, like, 5 minutes, automatically?
muru
  • 207,228
Put it in your crontab.
Open your cron table by:
crontab -e
Now add:
*/5 * * * * /path/to/script.sh
Don't forget to make the script executable beforehand.
As your script depends on X, probably will be a good idea to add the DISPLAY to the script's environment:
*/5 * * * * DISPLAY=:0 /path/to/script.sh
Replace :0 with your actual DISPLAY (can be found by echo $DISPLAY from interactive session).
If needed, you can add the XAUTHORITY environment variable too:
*/5 * * * * DISPLAY=:0 XAUTHORITY="~/.Xauthority" /path/to/script.sh
Again you can find the value by echo $XAUTHORITY.
heemayl
  • 93,925
17
The lazy option
If you want the easy way, and avoid having to find out which environment variable to set:
  • Make sure your script includes the shebang
  • Make it executable
  • Add the following to Startup Applications:
    /bin/bash -c "sleep 15 && while true; do <path_to_your_script.sh> ; sleep 300; done"
    Dash > Startup Applications > Add. Add the command:
Explanation
If you run the script from your own environment (e.g. from a terminal window or from Startup Applications), a number of environment variables will be set. cron however runs your script with a limited set of environment variables.
Since your script no doubt uses the gsettings command:
gsettings get org.gnome.desktop.background picture-uri <wallpaper>
to set the wallpaper, almost certainly the command will break when run from cron.
The downside of "the lazy solution" is purely theoretical. A command that sleeps practically continuously means nothing to your system.
Additional info; alternatively
Reading this post, and from experiences in the past, I am pretty sure the DBUS_SESSION_BUS_ADDRESS environment variable needs to be set.
To do so, add the following section at the beginning of your script (below the shebang):
PID=$(pgrep gnome-session)
export DBUS_SESSION_BUS_ADDRESS=$(grep -z DBUS_SESSION_BUS_ADDRESS /proc/$PID/environ|cut -d= -f2-)
Then you should be able to successfully run it from cron.
You could however very well save the hustle, and choose the lazy option.
Jacob Vlijm
  • 85,475
