10
I'm currently working with Atom, and sometimes I want to open a terminal on the directory my working file is. To do this, I usually have to open the folder in nautilus (right clicking the file in atom) and then I open a terminal on that directory from nautilus (right click).
I wonder if there is a way to open the terminal in the file directory without having to open nautilus first.
lapisdecor
  • 1,647
  • 19
  • 39
Try this package, I think it has exactly what you want.
Also, I suggest you to install term3 package. It works great for me, and I just don't have to bother with switching the windows as the terminal window is inside the atom editor.
Good luck!
I use the terminal-plus package to open my terminal from within the Atom text editor. You can see the package in action in this short video clip I made here: http://www.youtube.com/watch?v=cFAzqvYoHJs&t=11m14s.
After installing the package, to start the terminal within Atom you can use the GUI or use cmd-shift-t on Mac or ctrl-shift-t on Windows/Linux to bring up a terminal in the editor. To spawn another terminal session you repeat the previous command.
An option could be Platformio IDE Terminal (terminal package for Atom).
Some ot their features are:
  • Terminal Naming
  • Color Coding
  • Sorting
  • Insert selected text
There are a lot of terminal packages you can use in Atom. The packages which I recommend are :-
  1. terminal-plus
  2. atom-terminal-panel
  3. term3
  4. atom-terminal
