[Running 14.04 LTS.]
I'm trying to setup the TPM chip on my T510. I've been following the instructions at https://askubuntu.com/a/414755/507853 but I'm having the following issue:
root@FEYNMAN:/lib/modules/4.2.0-30-generic/kernel/drivers/char/tpm# ls -la
total 148
drwxr-xr-x 3 root root  4096 Feb 23 20:08 .
drwxr-xr-x 9 root root  4096 Feb 23 20:08 ..
drwxr-xr-x 2 root root  4096 Feb 23 20:08 st33zp24
-rw-r--r-- 1 root root 11449 Feb 20 04:23 tpm_atmel.ko
-rw-r--r-- 1 root root 12097 Feb 20 04:23 tpm_crb.ko
-rw-r--r-- 1 root root 11857 Feb 20 04:23 tpm_i2c_atmel.ko
-rw-r--r-- 1 root root 15361 Feb 20 04:23 tpm_i2c_infineon.ko
-rw-r--r-- 1 root root 21321 Feb 20 04:23 tpm_i2c_nuvoton.ko
-rw-r--r-- 1 root root 25273 Feb 20 04:23 tpm_infineon.ko
-rw-r--r-- 1 root root 16145 Feb 20 04:23 tpm_nsc.ko
-rw-r--r-- 1 root root 14489 Feb 20 04:23 xen-tpmfront.ko
root@FEYNMAN:/lib/modules/4.2.0-30-generic/kernel/drivers/char/tpm# modprobe tpm_atmel.ko
modprobe: FATAL: Module tpm_atmel.ko not found.
root@FEYNMAN:/lib/modules/4.2.0-30-generic/kernel/drivers/char/tpm# modprobe tpm_crb.ko
modprobe: FATAL: Module tpm_crb.ko not found.
root@FEYNMAN:/lib/modules/4.2.0-30-generic/kernel/drivers/char/tpm# modprobe tpm_i2c_atmel.ko
modprobe: FATAL: Module tpm_i2c_atmel.ko not found.
root@FEYNMAN:/lib/modules/4.2.0-30-generic/kernel/drivers/char/tpm# modprobe tpm_i2c_infineon.ko
modprobe: FATAL: Module tpm_i2c_infineon.ko not found.
root@FEYNMAN:/lib/modules/4.2.0-30-generic/kernel/drivers/char/tpm# modprobe tpm_i2c_nuvoton.ko
modprobe: FATAL: Module tpm_i2c_nuvoton.ko not found.
root@FEYNMAN:/lib/modules/4.2.0-30-generic/kernel/drivers/char/tpm# modprobe tpm_infineon.ko
modprobe: FATAL: Module tpm_infineon.ko not found.
root@FEYNMAN:/lib/modules/4.2.0-30-generic/kernel/drivers/char/tpm# modprobe tpm_nsc.ko
modprobe: FATAL: Module tpm_nsc.ko not found.
root@FEYNMAN:/lib/modules/4.2.0-30-generic/kernel/drivers/char/tpm# modprobe xen-tpmfront.ko
modprobe: FATAL: Module xen-tpmfront.ko not found.
I've tried rebooting but it makes no difference. The TPM is already enabled/active from my previous Windows 10 install (I also double-checked in BIOS just to be sure.)
Is someone able to help?
Try running depmod -a and then repeat your modprobe commands.
According to the man modprobe:
modprobe expects an up-to-date modules.dep file, as generated by depmod. This file lists what other modules each module needs (if any), and modprobe uses this to add or remove these dependencies automatically.
As soon as this file was updated, use modprobe command without paths and .ko extension:
modprobe module_name
whtyger
  • 5,900
  • 36
  • 48
