I know that one should never want to do this, but I need to run a command as root at startup. For some reason the driver for my wifi card isnt recognized so to get it up and running I have to run
sudo modprobe <drivername>
each time i boot.
How do I automate this? I don't think I can add a root command to my bash profile.
Side note: Extra points if you can tell me how to do this in fish shell.
I know this answers your problem (rather than the question), but if you want a module to be loaded at startup, simply add it to the file /etc/modules
e.g.
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
lp
<drivername>   <--- **here**
First you need to add a user yo run as root without a password and assign the program.
username ALL=(ALL:ALL)
NOPASSWD:/path/to/command
Replace username and /path/to/ with real values.
Then you can add the program to your startup programs.
Open the Dash type: "Startup Applications"
Now click on Add and give in the command to run that runs application.
DnrDevil
  • 1,478
