Not sure if I did it right, and the file got changed to a .img.dmg ... not sure how that works. And not sure how long the sudo dd command should take?
Asked
Active
Viewed 152 times
Using Mac to make bootable USB.
Turn the ISO to an IMG; You first need to rename that and remove the '.dmg' part. It will ask you if you're sure you want to change the file extension; click yes.
Then you can perform the
sudo dd if=Dev/sdx of /path/to/.img
Edit: As for how long it takes, it's usually between 5 and 15minutes for my MacBook Air to produce an Ubuntu usb
DnrDevil
- 1,478
