As I was requested by Pilot6 I'm attaching the link to the previous question asked: How to join Ubuntu 15.04 / 15.10 to Windows domain
I am on Ubuntu 15.10 and trying to use Likewiseopen to join to active directory. From what I tried, I've followed the guides to add the service of Lwsmd due to the systemd difference from 14.xx but it doesn't work out, it keeps failing. anyone ran into such issue aswell? Anyone been there and was a pro enough to find a solution?
If so, please share and help me find a solution too.
Thank you all!
I may be a bit late and I'm not sure what you have tried already, but I have worked with PBIS Open myself before and I just installed Ubuntu 15.10 on my VirtualBox environment to refresh my memory again.
If you get the following error I may know a solution to your problem. Ubuntu 15.10 PBIS Open lwsmd error
To solve this, you should check out the answer at the following link
I tried it again on my own VirtualBox machine with Ubuntu 15.10 and it worked for me. success domain join
So good luck!
mpmv15
  • 16
