I already searched around the web and couldn't find an answer.
These days lots of computers (mainly laptops) come with Ubuntu preinstalled.
Just out of curiosity, what is the default admin username/password? For example, if I want to install something from the Software Center or run a command with sudo, what is the password for that?
Does Ubuntu ask you for a username/password in the first boot when it comes preinstalled?
Eduardo Cola
  • 5,876
  • 20
  • 33
Default username: ubuntu
Default password: ubuntu
tread
  • 335
  • 19
There is no default password in OEM installations.
When you start the system for the first time it suggests to set a password.
If you do not get this prompt, it means that someone used the system and has set a password.
You can always reset the administrator password using this answer.
Pilot6
  • 92,041
I had the same issue and found this thread useful: https://ubuntuforums.org/showthread.php?t=2456500
The default OEM password was password. After that I was able to run "prepare shipment to end user" and finish the setup.
There is also some information claiming that BIOS reset is necessary: https://www.dell.com/community/Linux-General/Dell-recovery-problem/td-p/7889072
smihael
  • 216
In Ubuntu 24.04 server, the default username and password is ubuntu, but it is only accessible (at least by default) through the command line, and it has to be changed as soon as the user is logged in. However, no password-based ssh access by default!
atsag
