After upgrade to 15.10 I have been unable to activate hibernation from the start/stop menu. Doing so the following error appear in dmesg:
PM: Swap header not found!
I have checked again that my:
/etc/polkit-1/localauthority/50-local.d/com.ubuntu.enable-hibernate.pkla
file contains what is being advised in this article.
At the same time using sudo pm-hibernate from the terminal works flawlessly.
whtyger
  • 5,900
  • 36
  • 48
Since you say you can use pm-hibernate without any problem, it means there is no issue in your hibernate setting. Therefore, the problem should be in the settings of menu button. Again, you have mentioned that you are following the same setting which was prescribed here.
As per my understanding, and regarding the fact that you have been facing with this right after upgrading to Ubuntu 15.10, I think your system needs a new configuration for the button. Go through these steps:
Remove the content of /etc/polkit-1/localauthority/50-local.d/com.ubuntu.enable-hibernate.pkla and restart you system. Now any configuration for the hibernate button should be removed from the system.
After booting up, open the file again and paste those few lines mentioned in the link into the file and save. Restart your system again.
If everything goes properly, the button should be configured for Ubuntu 15.10
