From the MAN PAGES:
Shutdown - "shutdown arranges for the system to be brought down in a safe way. All
logged-in users are notified that the system is going down and, within
the last five minutes of TIME, new logins are prevented." Time mentioned here is an amount specify by the user that is shutting down.
Halt - "These programs allow a system administrator to reboot, halt or poweroff
the system."
The difference is that Halt can be more "aggressive" when shutting down than Shutdown itself. It has parameters than can literally force the system to shutdown without regarding services or opened programs. If you run halt without any parameters it will simply execute the shutdown command. Something like an alias. If you run it for example with the parameter --force it will "force" the system into a reboot really fast.
In the case of halt or shutdown, they will wait for all processes to finish correctly before turning the PC off or rebooting. If a service or app does not close or does not close properly you will see what you mention there (The ubuntu logo with the dots).
The proper way in the terminal for a single user or multi user is shutdown. But if the shutdown is not working verify what services you have running and which one is causing the slowness or freezing of the shutdown.
With that in mind, there are several ways to reboot or shutdown the system:
Rebooting - shutdown -r, reboot
In this case, reboot is simply calling shutdown -r.
Shutting Down - halt, shutdown, sudo init 0, shutdown -h now, poweroff
In this case, poweroff is the same as calling shutdown -P
As you have noticed, The shutdown command can do a lot of stuff, here is a small list of it:
-r Requests that the system be rebooted after it has been brought down
-h Requests that the system be either halted or powered off after it has been brought down, with the choice as to which left up to the system
-H Requests that the system be halted after it has been brought down
-P Requests that the system be powered off after it has been brought down
-c Cancels a running shutdown. TIME is not specified with this option, the first argument is MESSAGE
-k Only send out the warning messages and disable logins, do not actually bring the system down
As does the reboot
-f, --force force reboot or halt, don't call shutdown(8)
-p, --poweroff switch off the power when called as halt
There is however a difference between shutdown down through the terminal and clicking on the Shutdown option in Unity. The latter will ask the user for interaction with any unsaved work (like libreoffice, inkscape...). the former will simply send a signal to all processes telling them to close. No user interaction will be needed so any unsaved work will be gone.
