I have tried several alternatives from answers to similar questions (1, 2 and 3) (see also below) to get the libraries I need. It still doesn't work and I get this error message when trying to run my 32-bit software on my 64 bit system (Lubuntu 15.10):
$ ./aiStarter: error while loading shared libraries: libz.so.1: cannot open shared object file: No such file or directory
[1]+  Exit 127                ./aiStarter
So this is what I've tried:
$ sudo dpkg --add-architecture i386
$ sudo apt-get install libstdc++6:i386
Reading package lists... Done
Building dependency tree
The following package was automatically installed and is no longer required:
  libc6-i386
Use 'apt-get autoremove' to remove it.
The following extra packages will be installed:
  gcc-5-base:i386 libc6:i386 libgcc1:i386
Suggested packages:
  glibc-doc:i386 locales:i386
The following NEW packages will be installed:
  gcc-5-base:i386 libc6:i386 libgcc1:i386 libstdc++6:i386
0 upgraded, 4 newly installed, 0 to remove and 1 not upgraded.
Need to get 4 537 kB of archives.
After this operation, 12,0 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y    #Answered yes, etc...
$ sudo apt-get install package:i386
E: Unable to locate package package
$ sudo apt-get install build-essential:i386
 build-essential:i386 : Depends: gcc:i386 (>= 4:5.2) but it is not going to be installed
                    Depends: g++:i386 (>= 4:5.2) but it is not going to be installed
                    Depends: dpkg-dev:i386 (>= 1.17.11)
Also tried my hand at finding exactly what package it is I actually need (not sure if it's even the correct way):
$ apt-file update
$ sudo apt-file -x search '/libz.so.1$'
E: The cache is empty. You need to run 'apt-file update' first.
Other ways I should try?
Ingrid
  • 371
Install dependencies 32 bits in 64 bit envirennements:
sudo apt-get install build-essential gcc-multilib gcc-4.8-multilib g++-multilib g++-4.8-multilib lib32z1 lib32ncurses5 lib32bz2-1.0 libc6-dev libgmp-dev libmpfr-dev libmpc-dev
Install the librarie
GAD3R
  • 3,748
Installing the following solved my problem: cpp-5:i386, gcc:i386, g++:i386 and dpkg-dev:i386. (I noticed that you could actually read something out from the last error message in my question.)
Ingrid
  • 371
Your attempt to locate the missing package containing the 32 bit libz would have succeeded if you had not used "sudo". The output contains several possibilities, lib32z1:i386 or libx32z1:i386 being reasonable choices. If you successfully build your 32 bit executable, and the load started, you apparently have all the other parts needed to execute 32 bit executables.
ubfan1
  • 19,049
