I have a list of ranges for IP addresses that I want to block, the ranges are like 210.80.32.0 to 210.80.63.255
How can I dynamically determine the right 210.80.32.0/NUMBER to capture the full range?
sudo ufw deny 210.80.32.0/???
I am reading these IP ranges in once a month from text files to add to my firewall rules, I tear the firewall down once a month and rebuild it to capture any changes in these ranges. Currently I am just doing lowerrange/20 in the rule.
So I need to get the two network values by splitting the string on . then do the math to determine how many there are.. and add a rule for each network?
JoGotta
  • 13
You are using CDIR notation here. You may want to read more about CDIR notation and subnet masks.
In your example, you could break out the two networks into:
  1. 210.80.32.0/24
  2. 210.80.33.0/24
This translates to:
  • 255.255.255.0
or:
  1. 210.80.32.0-254
  2. 210.80.33.0-254
You should now be able to perform:
sudo ufw deny 210.80.32.0/24 && sudo ufw deny 210.80.33.0/24
Other examples
You could block 210.80.0.0/16, which would block 210.80.0-254.0.254, but this will block IPs in ranges not specified in the original post.
earthmeLon
  • 11,658
