65
What is the Ubuntu linux command to find laptop monitor size? I want to know in inches if possible.
Thanks
Jacob Vlijm
  • 85,475
user111
  • 721
5 Answers5
73
Another option, using xrandr, is the command:
xrandr | grep ' connected'
Output:
DVI-I-1 connected primary 1680x1050+0+0 (normal left inverted right x axis y axis) 473mm x 296mm
VGA-1 connected 1280x1024+1680+0 (normal left inverted right x axis y axis) 376mm x 301mm
(mind the space before connected, else disconnected will be included)
Important differences between xdpyinfo and xrandr
  • While xrandr lists screens separately (in case of multiple monitors), xdpyinfo outputs one single set of dimensions for all screens together ("desktop size" instead of screen size)
  • As noticed by @agold there is (quite) a difference between the two, which seems too big to be a simple rounding difference:
    xrandr: 473mm x 296mm
    xdpyinfo: 445x278
It seems related to a bug in xdpyinfo. See also here.
If you'd insist on inches
Use the small script below; it outputs the size of your screen(s) in inches; width / height / diagonal (inches)
#!/usr/bin/env python3
import subprocess
# change the round factor if you like
r = 1
screens = [l.split()[-3:] for l in subprocess.check_output(
    ["xrandr"]).decode("utf-8").strip().splitlines() if " connected" in l]
for s in screens:
    w = float(s[0].replace("mm", "")); h = float(s[2].replace("mm", "")); d = ((w**2)+(h**2))**(0.5)
    print([round(n/25.4, r) for n in [w, h, d]])
To use it:
Copy the script into an empty file, save it as get_dimensions.py, run it by the command:
python3 /path/to/get_dimensions.py
Output on my two screens:
width - height - diagonal (inches)
[18.6, 11.7, 22.0]
[14.8, 11.9, 19.0]
Edit
Fancy version of the same script (with a few improvements and a nicer output), looking like:
Screen  width   height  diagonal
DVI-I-1 18.6    11.7    22.0
VGA-1   14.8    11.9    19.0
The script:
import subprocess
r = 1
screens = [l.split() for l in subprocess.check_output(
scr_data = []
for s in screens:
    try:
        scr_data.append((
            s[0],
            float(s[-3].replace("mm", "")),
            float(s[-1].replace("mm", ""))
    except ValueError:
        pass
print(("\t").join(["Screen", "width", "height", "diagonal\n"+32*"-"]))
for s in scr_data:
    scr = s[0]; w = s[1]/25.4; h = s[2]/25.4; d = ((w**2)+(h**2))**(0.5)
    print(("\t").join([scr]+[str(round(n, 1)) for n in [w, h, d]]))
EDIT 2 (May 2019)
"Kind of" on request (in a comment), a modernized / more advanced / improved (no system calls, no parsing but using Gdk.Display) version, doing pretty much exactly the same:
import gi
gi.require_version('Gdk', '3.0')
from gi.repository import Gdk
dsp = Gdk.Display.get_default()
n_mons = dsp.get_n_monitors()
for i in range(n_mons):
    mon = dsp.get_monitor(i)
    mon_name = mon.get_model()
    w = mon.get_width_mm()/25.4
    h = mon.get_height_mm()/25.4
    print(("\t").join([mon_name]+[str(round(n, 1)) for n in [w, h, d]]))
Output:
eDP-1   20.0    11.3    23.0
HDMI-1  18.6    11.7    22.0
I will leave the original answer, since it seems inappropriate to remove the answer after such a long time, that generated the existing votes.
Jacob Vlijm
  • 85,475
34
How'bout this :
xrandr | awk '/ connected/{print sqrt( ($(NF-2)/10)^2 + ($NF/10)^2 )/2.54" inches"}'
and through SSH :
ssh server DISPLAY=:0 xrandr | awk '/ connected/{print sqrt( ($(NF-2)/10)^2 + ($NF/10)^2 )/2.54" inches"}'
SebMa
  • 2,927
  • 35
  • 47
18
Just in case you want a more general answer, you can cut the the gordian knot, and use a non-geeky physical ruler for that. As per this wiki, the "size of a screen is usually described by the length of its diagonal":
If you have a ruler that only displays centimeters, you can use the simple conversion:
1 cm = 0.393701 in
(or 2.54 cm = 1 in)
So if your ruler measures 30 centimeters, your screen is 11.811 inches. You can also use google with a query of the form 30 cm to in.
Image credits: https://en.wikipedia.org/wiki/File:Display_size_measurements.png
phresnel
  • 283
10
Xdpyinfo is a utility for displaying information about an X server. It is used to examine the capabilities of a server, the predefined values for various parameters used in communicating between clients and the server, and the different types of screens and visuals that are available.
The command to get the monitor size is:
xdpyinfo | grep dimensions
Result
dimensions:    1366x768 pixels (361x203 millimeters)
Parto
  • 15,647
This was something that I too was struggling with(when I wanted to upgrade to a new monitor for myself and wanted to know what size my old monitor was), so I wrote a shell script that finds the monitor size for you.
I used the xdpyinfo from the first answer to get the screen dimensions and built ahead on it. The script essentially computes the diagonal from the screen dimensions, converting from millimeters to inches and displays the result.
Repository URL: https://github.com/abhishekvp/WhatsMyScreenSize
Hope this helps!
