I encountered a problem trying to install couchdb on my Ubuntu 14.10 (GNU/Linux 3.10.23-xxxx-std-ipv6-64 x86_64) server.
When I run apt-get install couchdb,
I've got the following mistakes :
The following packages have unmet dependencies.
     couchdb : Depends: couchdb-bin (>= 1.6.1-0ubuntu4)
     but it is not going     to be installed
I followed a lot of steps found on the net to try to fix it, but nothing worked...
I hope someone will be able to find out what's going wrong...
Thanks
EDIT:
Here are the steps I have already done :
- I tried to use Aptitude, but it installed Couchdb 1.0.1 instead of 1.6.1
- I tried to remove completely the installation using "apt-get remove couchdb couchdb-bin erlang-base erlang-base-hipe erlang-solutions" But the result was the same.
- The problem occurs when I add the PPA of couchdb to install the last version. If I remove the .plist, installation works, but it installs the 1.0.1 version.
- I tried all the possible solutions to update apt-get or to clean it...
Do you think that if I update my Ubuntu 14.10 to 15 it could fix the problem ?
