I tried java -version, but it returned something like:
java version "1.7.0_95"
OpenJDK Runtime Environment (IcedTea 2.6.4) (7u95-2.6.4-0ubuntu0.14.04.1)
OpenJDK Zero VM (build 24.95-b01, mixed mode)
According to the program I am trying to start, it requires Oracle(R) Java(TM) Runtime Environment 7 or 8.
inf3rno
  • 262
  • 14
You need Oracle Java which you can install like this
sudo add-apt-repository ppa:webupd8team/java
sudo apt-get update
sudo apt-get install oracle-java8-installer
and then setup like this
sudo apt-get install oracle-java8-set-default
Right now you have OpenJDK and as per your question you need Oracle Java. In case the JAVA_HOME is not setup properly you can do:
sudo vi /etc/environment
export JAVA_HOME=/path-to-java-before-bin-dir
source /etc/environment
Ashu
  • 4,004
