I don't know that the following is the answer, I somewhat randomly arrived at this "solution" with help from the linux chat room on freenode IRC (thanks Jim and peetaur2):
thufir@mordor:~$
thufir@mordor:~$ sudo mkdir /etc/postfix /etc/dovecot/ /etc/dovecot/private/ /etc/dovecot/conf.d/
thufir@mordor:~$
thufir@mordor:~$ sudo apt-get install mail-stack-delivery
Reading package lists... Done
Building dependency tree
mail-stack-delivery is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 145 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
Setting up mail-stack-delivery (1:2.2.18-2ubuntu2) ...
grep: /etc/dovecot/conf.d/10-ssl.conf: No such file or directory
Postfix not configured. Run
sudo dpkg-reconfigure postfix and choose
the type of mail server. Then run
sudo dpkg-reconfigure mail-stack-delivery to
finish mail-stack-delivery installation.
thufir@mordor:~$
thufir@mordor:~$ sudo dpkg-reconfigure mail-stack-delivery
thufir@mordor:~$ sudo dpkg-reconfigure postfix
setting synchronous mail queue updates: true
Creating /etc/postfix/dynamicmaps.cf
Adding tcp map entry to /etc/postfix/dynamicmaps.cf
Adding sqlite map entry to /etc/postfix/dynamicmaps.cf
setting myhostname: mordor.bounceme.net
setting alias maps
setting alias database
setting myorigin
setting destinations: mordor.bounceme.net, localhost.bounceme.net, localhost
setting relayhost:
setting mynetworks: 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
setting mailbox_size_limit: 0
setting recipient_delimiter: +
setting inet_interfaces: loopback-only
setting default_transport: error
setting relay_transport: error
setting inet_protocols: all
WARNING: /etc/aliases exists, but does not have a root alias.
Postfix is now set up with a default configuration. If you need to make
changes, edit
/etc/postfix/main.cf (and others) as needed. To view Postfix configuration
values, see postconf(1).
After modifying main.cf, be sure to run '/etc/init.d/postfix reload'.
Running newaliases
Processing triggers for libc-bin (2.21-0ubuntu4) ...
thufir@mordor:~$
Mail stack delivery changes some postfix settings.
Old values are stored in /var/backups/mail-stack-delivery/main.cf-backup.
Feel free to revert any of them when the process is done.
Configuring postfix for mail-stack-delivery integration: .................... done.
thufir@mordor:~$
thufir@mordor:~$
thufir@mordor:~$ sudo dpkg --configure -a
thufir@mordor:~$
It's highly likely that something else broke the loop and allowed dpk and apt to run without error.
how can I fully purge this package, and all config?
useful CLI command I learned today: update-manager to bring up the apt GUI.
