28
Ok i need to extract a zip archive named 'example.zip' but i would like to extract it as a different file name, not 'example' being my folder name, how could i extract a zip archive using unzip called 'example.zip' and extract it as the folder name 'examplefold'
By default, unzip extracts the content of the archive directly into the current directory.
You can specify a different target directory where to extract the files using the -d option:
unzip example.zip -d /path/to/wherever/you/want/the/archive/to/get/extracted
Or if the archive itself contains a folder example which you want to extract to the current directory, but with a different name, you must manually rename it to examplefold afterwards:
unzip example.zip && mv example examplefold
Byte Commander
  • 110,243
Assume that you have some zip files with these names:
2.zip, 25.zip, 45.zip, ..., 10352.zip
Also, in each zip file there is a folder which is called tmp. I will write a bash file (say zz.sh) with this content:
for zipName in 2 25 45 65 85 110 264 1000 10352
do
    unzip $zipName.zip
    mv tmp tmp_$zipName
done
Then run the file by:
bash zz.sh
Soheil
