I'm having problems trying to install OpenCV 2.0 on Ubuntu 14.04. When I want to install the dependencies I got the following problem:
andres@andres-VirtualBox:~$ sudo apt-get install build-essential libgtk2.0-dev libavcodec-dev libavformat-dev libjpeg62-dev libtiff4-dev cmake libswscale-dev libjasper-dev
[sudo] password for andres:
Reading package lists...
Done Building dependency tree Reading state information...
Done Some packages could not be installed. This may mean that you have
distribution that some required packages have not yet been created or been
moved out of Incoming. The following information may help to resolve the
situation:
libtiff4-dev : Depends: libtiff5-dev (> 4.0.3-6~) but it is not going to be installed
I want to install OpenCV 2.0 because there is an old project that uses that version of OpenCV.
Update 1
1: I installed libtiff5-dev but then it threw another error:
libjpeg-turbo8-dev : Conflicts: libjpeg62-dev but 6b1-4ubuntu1 is to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Then I removed libjpeg-turbo8-dev but it uninstalled libtiff5-dev. Someone posted about the problem like 4 years ago without a solution:
http://ubuntuforums.org/showthread.php?t=1985957
Update 2
I used aptitude instead of apt-get to install the dependencies. Everything went ok but I checked that I have ffmpeg and v4l as no. I didn't care and I tried to compile the library. I got the following compilation errors:
In file included from ../include/opencv/cxcore.h:2123:0,
from cxcore/_cxcore.h:60,
from cxcore/cxprecomp.cpp:43:
../include/opencv/cxcore.hpp:169:13: error: ‘ptrdiff_t’ does not name a type
typedef ptrdiff_t difference_type;
In file included from ../include/opencv/cxcore.hpp:2243:0,
from ../include/opencv/cxcore.h:2123,
../include/opencv/cxoperations.hpp:1916:15: error: ‘ptrdiff_t’ does not name a type
static inline ptrdiff_t operator - (const FileNodeIterator& it1, const FileNodeIterator& it2)
../include/opencv/cxoperations.hpp:2465:31: error: ‘ptrdiff_t’ does not name a type
template<typename _Tp> inline ptrdiff_t operator - (const SeqIterator<_Tp>& a,
In file included from ../include/opencv/cxcore.hpp:2244:0,
../include/opencv/cxmat.hpp: In member function ‘void cv::Mat::locateROI(cv::Size&, cv::Point&) const’:
../include/opencv/cxmat.hpp:356:5: error: ‘ptrdiff_t’ was not declared in this scope
ptrdiff_t delta1 = data - datastart, delta2 = dataend - datastart;
../include/opencv/cxmat.hpp:356:5: note: suggested alternatives:
In file included from /usr/include/c++/4.8/utility:68:0,
from /usr/include/c++/4.8/algorithm:60,
from ../include/opencv/cxcore.hpp:51,
/usr/include/x86_64-linux-gnu/c++/4.8/bits/c++config.h:187:28: note: ‘std::ptrdiff_t’
typedef __PTRDIFF_TYPE__ ptrdiff_t;
../include/opencv/cxmat.hpp:356:15: error: expected ‘;’ before ‘delta1’
../include/opencv/cxmat.hpp:358:9: error: ‘delta1’ was not declared in this scope
if( delta1 == 0 )
../include/opencv/cxmat.hpp:367:31: error: ‘delta2’ was not declared in this scope
wholeSize.height = (int)((delta2 - minstep)/step + 1);
make[2]: *** [cxprecomp.lo] Error 1
make[2]: Leaving directory `/home/andres/OpenCV-2.0.0/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/andres/OpenCV-2.0.0'
make: *** [all] Error 2
