31
At work I'm using putty to connect to a lot of Red Hat / CentOS machines and I love the fact that selecting a text means copy and right click means paste.
Can I set Ubuntu's default terminal to do the same?
Edit: Thanks for the answers, but they are not exactly what I am looking for. While both are valid, I was actually looking for a way to use the functionality without using another terminal. So everything should work via the default gnome terminal.
I am not sure it's possible, but I'll try my luck and start a bounty on this...
Edit: Thank you guys for your answers and sorry for the late reply but I was out over the week-end. I'll check the "selection/middle mouse button" solution tonight and come back to you.
The patch solution sounds also promising.
bioShark
  • 4,315
In gnome-terminal (and in Ubuntu in general) select text means "copy" (or "X selection" if you want to get technical, which is different from "clipboard copy"), which can be pasted via middle mouse click.
Stunts
  • 2,262
Let me expand on my original answer a little bit. Technically, the default terminal emulator, the gnome-terminal does not have this functionality and there's no way to set it as far as I know or have seen from researching online. Therefore the answer to your question
is basically, no.
On the other hand, putty is actually also available for Ubuntu, and that is the simplest , least-effort solution if you want a specific behavior. Do sudo apt-get install putty to get it.
There is however a few compromises that you can adopt, and they exist the way they are for historical reasons. The graphical environment under Unix/Linux X server has something known as selections, think of them as multiple clipboards - primary, secondary, and "clipboard". The second selection is when you highlight text and use ShiftInsert or middle mouse click to paste. Middle mouse click is scroll wheel click on mouses, and on touchpads - right and left click pressed together.
There are solutions with other terminals but since you request gnome-terminal specifically, the answer still remains , no, there's no other way.
I found this patch by Tomi Valkeinen: Gnome-terminal patch for putty-like right mouse button paste
Let us know if it works for you.
Edit: I went ahead and checked it myself. It works perfectly. Here are the patched deb files for gnome-terminal-3.6.2: uploaded in mediafire
If you are using the same version of gnome-terminal, you can download the deb files and install it by:
cd /path/to/download/folder
sudo dpkg -i gnome-terminal_3.6.2-0ubuntu1_amd64.deb gnome-terminal-data_3.6.2-0ubuntu1_all.deb
Edit: For future reference, here is the full procedure:
Download the patch: right-button-paste.patch
Install build dependencies:
sudo apt-get build-dep gnome-terminal
Download the sources and apply the patch:
mkdir gnome-terminal
cd gnome-terminal
sudo apt-get source gnome-terminal
cd gnome-terminal-*
patch -p1 < path/to/right-button-paste.patch
Build and install:
sudo dpkg-buildpackage -us -uc -b
cd ..
dpkg -i *.deb
Up to date patches are maintained by Tomi Valkeinen at https://github.com/tomba/gnome-terminal under 'paste-*' branches.
banskt
  • 359
Solution for this is to use Terminator, an Linux terminal: Terminator
Also here is a tutorial how to do this: Right click paste on linux terminal with terminator
