I'm trying read it loud feature of acrobat, so need a text synthesizer, I've installed espeak and libgnome-speech libraries (it didn't work for acrobat right out of the box) so when I started espeak-gui through command line it gave me segmentation fault next I tried only espeak and here is output:
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib audio/pcm_bluetooth.c:1613:(audioservice_expect) BT_GET_CAPABILITIES failed : Input/output error(5)
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Cannot connect to server socket err = No such file or directory
jack server is not running or cannot be started
Any ideas? or any alternative solutions for read it loud?
Thanks
