I have a desktop computer with a Radeon R7 360 and FOS-drivers. My main display, which I am using always, is connected to the DVI-port and my TV is connected to the HDMI-out, in case I want to put any videos or films on or just need an extra display.
However, when I turn my TV on and it is recognised by Ubuntu, the additional space is always added to the wrong side. I usually choose to "expand the desktop to the right side", but what actually happens is my main desktop is then displayed on the TV and my regular monitor is "added" to its space. I then always have to go into the settings and drag the displays in correct order, this setup is also not saved, since I have to redo this procedure every time I turn on my TV to expand my desktop.
Is there any solution for this or does someone have an idea on where to set up a fixed configuration for my two displays?
I am currently using Ubuntu Studio 15.10 with Xfce.
Edit: This is the output of xrandr:
Screen 0: minimum 320 x 200, current 4480 x 1080, maximum 16384 x 16384
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected 1920x1080+2560+0 (normal left inverted right x axis y axis) 160mm x 90mm
   1920x1080     60.00*+  50.00    59.94    30.00    25.00    24.00    29.97    23.98
   1920x1080i    60.00    50.00    59.94
   1280x1024     60.02
   1360x768      60.02
   1152x864      59.97
   1280x720      60.00    50.00    59.94
   1024x768      60.00
   800x600       60.32
   720x576       50.00
   720x576i      50.00
   720x480       60.00    59.94
   640x480       60.00    59.94
   720x400       70.08
DVI-0 connected primary 2560x1080+0+0 (normal left inverted right x axis y axis) 673mm x 284mm
   2560x1080     60.00*+
   1920x1080     60.00
   1680x1050     59.88
   1280x1024     75.02    60.02
   1280x800      59.91
   1152x864      75.00
   1024x768      75.08    60.00
   800x600       75.00    60.32
   640x480       75.00    60.00
   720x400       70.08
Prototype700
  • 1,120
It appears your TV is physically disconnected when you switch it off, else it won't possibly lose the set up. Below two options to solve the issue, which is most likely the result of a bug:
  1. The (background) script below (option [1.] should automatically move the TV screen (in your case: HDMI-0) to the right of your main screen, if it was connected after being disconnected.
  2. The keyboard shortcut does the same, but manually after connecting (switching on) the TV.
1. A background script, automatically setting the second screen
The script is written in such a way that it takes the screen you want to appear on the right (the one that is disconnected now and then) as an argument (see explanation below). Therefore, it works with any combination of screens, you only need to enter the name of the right screen into the command. The script will find the resolution of the left screen, for correct positioning.
The script
#!/usr/bin/env python3
import subprocess
import time
import sys
This script is a fix for what is presumably a bug, causing the secundary screen
to appear on the left side instead of the right side of the "main" screen.
Run it in the background.
#--- set your secundary (right) screen below
sec = sys.argv[1]
scr_id = sec+" connected"
def get_xrandr():
    return subprocess.check_output("xrandr").decode("utf-8")
def get_setup():
    # returns output of xrandr if secundary monitor was connected (else None)
    get_xr = subprocess.check_output("xrandr").decode("utf-8")
    if scr_id in get_xr:
        return get_xr
def get_xshift(xr):
    # find connected screens (lines)
    mons = [l for l in xr.splitlines() if " connected" in l]
    # get name and x-size of main screen
    left = [l.split() for l in mons if not l.startswith(scr_id)][0]
    return [(left[0], s.split("x")[0]) for s in left if s.count("+") == 2][0]
check1 = []
while True:
    time.sleep(4)
    check2 = get_setup()
    if check1 != check2:
        # on change in monitor setup:
        if check2 != None:
            # if secundary monitor was just connected
            print("run setup")
            x_shiftdata = get_xshift(check2)
            cmd1 = ["xrandr",  "--output", x_shiftdata[0], "--pos", "0x0"]
            cmd2 = ["xrandr",  "--output", sec, "--pos", x_shiftdata[1]+"x0"]
            for cmd in [cmd1, cmd2]:
                subprocess.call(cmd)
    check1 = check2
How to use
  1. Copy the script into an empty file, save it as screen_set.py
  2. Test- run it with the secondary screen as an argument with the command:
    python3 /path/to/screen_set.py HDMI-0
    (since HDMI-0 is your secondary screen) Disconnect (switch off) the TV and connect it again, it should appear on the right side.
  3. If all works fine, add it to Startup Applications, with a little break: Dash > Startup Applications > Add. Add the command:
     /bin/bash -c "sleep 15 && python3 /path/to/screen_set.py HDMI-0"
Now it should be solved.
2. Alternatively; a keyboard shortcut
The background script adds practically nothing to the processor load, and will not be noticed whatsoever. If you however would prefer a keyboard shortcut to an (automatically working) background script, add the command:
/bin/bash -c "xrandr --output DVI-0 --pos 0x0 && xrandr --output HDMI-0 --pos 2560x0"
which will do the same, but manually: Choose: System Settings > "Keyboard" > "Shortcuts" > "Custom Shortcuts". Click the "+" and add the command:
Explanation; the background script
  • Once per four seconds, the script checks if the TV is connected by checking if the string HDMI-0 connected is in the output of the command xrandr.
  • (Only) if there is a change in the state: False -> True, the script runs the command (in your case):
    which arranges your screens from left to right, as explained here. If your screen resolutions are different however, the script looks up the correct figures and the name of the main screen. As long as you use the secondary screen as an argument, it works fine.
Jacob Vlijm
  • 85,475
I have an ATI R5 card that never saves my graphics layout for my three monitors using xfce4-display-settings. ARandR should solve your issue. Install by typing the following in terminal:
sudo apt-get install arandr
Use ARandR to configure your screens, save it to a script (Layout > Save As), and set it to run as a Session and Startup > Application Autostart item. (You may need to set it to sleep 5 first before running the layout script.)
If you have two different layouts that you use, you can configure each of those with ARandR. Then you can run one script or the other depending on which layout you want. Or, better yet, you could assign each to their own keyboard shortcut if so desired.
jbrock
  • 3,417
