My wifi is not working. The ethernet works well. Wifi also works in windows dual boot. Hence it isnt hardware problem. Please advice.
iwconfig
eth0      no wireless extensions.
lo        no wireless extensions.
wlan0     IEEE 802.11bgn  Mode:Master  Tx-Power=20 dBm
Retry  long limit:7   RTS thr=2347 B   Fragment thr:off
      Power Management:off
dmesg | grep Wireless
[   14.639861] input: HP Wireless hotkeys as /devices/virtual/input/input6
lspci
00:00.0 Host bridge: Intel Corporation Broadwell-U Host Bridge -OPI (rev 09)
00:02.0 VGA compatible controller: Intel Corporation Broadwell-U Integrated Graphics (rev 09)
00:03.0 Audio device: Intel Corporation Broadwell-U Audio Controller (rev 09)
00:14.0 USB controller: Intel Corporation Wildcat Point-LP USB xHCI Controller (rev 03)
00:16.0 Communication controller: Intel Corporation Wildcat Point-LP MEI Controller #1 (rev 03)
00:1b.0 Audio device: Intel Corporation Wildcat Point-LP High Definition Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #1 (rev e3)
00:1c.1 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #2 (rev e3)
00:1c.2 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #3 (rev e3)
00:1c.4 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #5 (rev e3)
00:1c.5 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #6 (rev e3)
00:1d.0 USB controller: Intel Corporation Wildcat Point-LP USB EHCI Controller (rev 03)
00:1f.0 ISA bridge: Intel Corporation Wildcat Point-LP LPC Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation Wildcat Point-LP SATA Controller [AHCI Mode] (rev 03)
00:1f.3 SMBus: Intel Corporation Wildcat Point-LP SMBus Controller (rev 03)
00:1f.6 Signal processing controller: Intel Corporation Wildcat Point-LP Thermal Management Controller (rev 03)
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
08:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 07)
09:00.0 3D controller: NVIDIA Corporation GF117M [GeForce 610M/710M/820M / GT 620M/625M/630M/720M] (rev a1)
0a:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter
lspci -knn | grep Net -A2
0a:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter [10ec:b723]
    Subsystem: Hewlett-Packard Company Device [103c:2231]
    Kernel driver in use: rtl8723be
rfkill list
0: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
1: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
ifconfig && iwconfig && route -n && ping -c 1 google.com
eth0      Link encap:Ethernet  HWaddr d0:bf:9c:0a:ce:7d
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:15178 errors:0 dropped:0 overruns:0 frame:0
          TX packets:15216 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:11868737 (11.8 MB)  TX bytes:1948892 (1.9 MB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:1699 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1699 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:240328 (240.3 KB)  TX bytes:240328 (240.3 KB)
wlan0     Link encap:Ethernet  HWaddr 74:29:af:94:27:59
          inet addr:10.10.0.1  Bcast:10.10.0.255  Mask:255.255.255.0
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:56 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:9877 (9.8 KB)
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
10.10.0.0       0.0.0.0         255.255.255.0   U     0      0        0 wlan0
ping: unknown host google.com
According to iwconfig, your device is set to Master mode:
In order to connect to an access point, it should be set to Managed, also known as Infrastructure. Please click the Network Manager icon, select 'Edit Connections' and delete all previous connections. Then, under Wifi, select Infrastructure.
Then, check under IPv4 settings and under Method, select 'Automatic(DHCP)'; be certain it is NOT set to shared.
Save and close. Restart Network Manager:
sudo service network-manager restart
Now see if the NM icon sees your network and will connect.
It may take a reboot.
chili555
  • 61,330
