I am on Ubuntu 12.04. I need to mount a webdav directory, and it is critical non sudoers may access it.
I followed these instructions: http://techiech.blogspot.de/2013/04/mounting-webdav-directory-in-linux.html
Mounting the directory with sudo now works, but credentials are being asked.
Mounting as non suoders results in :
/sbin/mount.davfs:/etc/davfs2/davfs2.conf:35: user option in system configuration file
/sbin/mount.davfs:/home/<username>/.davfs2/davfs2.conf:24: system option in user configuration file
and apparently nothing happens, and I need to hit ctrl+c to get the prompt again.
The lines pointed at in davfs2.conf correspond to uncommented lines:
ignore_home       kernoops,distccd
secrets         ~/.davfs2/secrets
Any idea what may be wrong ?
Vince
  • 195
Try to mount it within /etc/fstab you must be installed davfs2
paste this line to /etc/fstab
https://somedomain.xyz/webdav.php/somefolder/ /mnt/s02 davfs,_netdev defaults 0 0
then
mount -a
