My problem is pretty much identical to here except none of the solutions there are working for me. I'm assuming the issue there was for python 2.7 because my issue is specific to python 3.5.1
TL;DR: The following commands all do not work, details below
  • sudo apt-get install libtiff5
  • sudo dpkg -i libtiff5_4.0.3-7ubuntu0.3_amd64.deb
  • python setup.py install (pylibtiff, a libtiff wrapper)
  • conda install libtiff
  • pip install libtiff
What I've tried:
Karel's Method
cornelis@Bob:~$ sudo apt-get install libtiff5
Reading package lists... Done
Building dependency tree
libtiff5 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 342 not upgraded.
cornelis@Bob:~$ python
Python 3.5.1 |Anaconda 2.4.1 (64-bit)| (default, Dec  7 2015, 11:16:01)
[GCC 4.4.7 20120313 (Red Hat 4.4.7-1)] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> from libtiff import TIFF
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
ImportError: No module named 'libtiff'
ShubhamGG's method (Modified for libtiff5)
cornelis@Bob:~/Downloads$ sudo dpkg -i libtiff5_4.0.3-7ubuntu0.3_amd64.deb
(Reading database ... 228352 files and directories currently installed.)
Preparing to unpack libtiff5_4.0.3-7ubuntu0.3_amd64.deb ...
Unpacking libtiff5:amd64 (4.0.3-7ubuntu0.3) over (4.0.3-7ubuntu0.3) ...
Setting up libtiff5:amd64 (4.0.3-7ubuntu0.3) ...
Processing triggers for libc-bin (2.19-0ubuntu6.6) ...
cornelis@Bob:~/Downloads$ python
  File "/home/cornelis/Downloads/libtiff/__init__.py", line 20, in <module>
    from .libtiff_ctypes import libtiff, TIFF, TIFF3D
  File "/home/cornelis/Downloads/libtiff/libtiff_ctypes.py", line 31
    print 'You should add %r to PATH environment variable and reboot.' % (os.path.dirname (lib))
SyntaxError: invalid syntax
I'm not sure what the %r to PATH environment variable means. However, I did reboot. No effect.
Next I tried pylibtiff:
cornelis@Bob:~/Downloads/pylibtiff-svn$ python setup.py install
Appending libtiff.bitarray configuration to libtiff
Ignoring attempt to set 'name' (from 'libtiff' to 'libtiff.bitarray')
Appending libtiff configuration to
Ignoring attempt to set 'name' (from '' to 'libtiff')
Warning: Assuming default configuration (libtiff/bitarray-0.3.5-numpy/bitarray/{setup_bitarray,setup}.py was not found)Traceback (most recent call last):
  File "setup.py", line 96, in <module>
    configuration = configuration,
  File "/home/cornelis/anaconda3/lib/python3.5/site-packages/numpy/distutils/core.py", line 135, in setup
    config = configuration()
  File "setup.py", line 67, in configuration
    config.get_version('libtiff/version.py')
  File "/home/cornelis/anaconda3/lib/python3.5/site-packages/numpy/distutils/misc_util.py", line 1918, in get_version
    version_module = imp.load_module('_'.join(n.split('.')),*info)
  File "/home/cornelis/anaconda3/lib/python3.5/imp.py", line 234, in load_module
    return load_source(name, filename, file)
  File "/home/cornelis/anaconda3/lib/python3.5/imp.py", line 172, in load_source
    module = _load(spec)
  File "<frozen importlib._bootstrap>", line 693, in _load
  File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 658, in exec_module
  File "<frozen importlib._bootstrap_external>", line 764, in get_code
  File "<frozen importlib._bootstrap_external>", line 724, in source_to_code
  File "<frozen importlib._bootstrap>", line 222, in _call_with_frames_removed
  File "libtiff/version.py", line 30
    print version
SyntaxError: Missing parentheses in call to 'print'
Conda attempt
cornelis@Bob:~/Downloads$ conda install libtiff
Fetching package metadata: ....
Solving package specifications: ....................
# All requested packages already installed.
# packages in environment at /home/cornelis/anaconda3:
libtiff                   4.0.6                         1
Pip attempt
cornelis@Bob:~/Downloads$ pip install libtiff
Collecting libtiff
  Using cached libtiff-0.4.0.tar.gz
    Complete output from command python setup.py egg_info:
      File "<string>", line 1, in <module>
      File "/tmp/pip-build-90idcgcx/libtiff/setup.py", line 96, in <module>
      File "/tmp/pip-build-90idcgcx/libtiff/setup.py", line 67, in configuration
        print version
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-90idcgcx/libtiff
Frikster
  • 205
