Can VeraCrypt use persistent mount points on Linux?
Windows + VeraCrypt + encrypted volume absolute paths
On Windows I can mount veracrypt encrypted partitions/disks via batch script which employs device name displayed by mountvol.exe. Such an attribute is highly useful since rebooting can lead to alteration of relative path (\Device\Harddisk1\Partition3 --> reboot --> \Device\Harddisk3\Partition3).
My batch script for veracrypt volumes on Windows (shortened form):
@echo
"C:\Program Files\VeraCrypt\VeraCrypt.exe" /v \\?\Volume{xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx}\ /l z /m label=Encrypted_1 /q
"C:\Program Files\VeraCrypt\VeraCrypt.exe" /v \\?\Volume{yyyyyyyy-yyyy-yyyy-yyyy-yyyyyyyyyyyy}\ /l f /m label=Encrypted_2 /q
pause
Linux + VeraCrypt + encrypted volume relative paths only?
I have no knowledge about the existence of parallel command to Windows' /v \\?\Volume{xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx}\ avaliable for the Linux commandline. I tried (in vain) --mount=/dev/disk/by-uuid/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx flag, since mountvol.exe volume name is (probably) based on UUID number (imperceptible for blkid, though). Official veracrypt/truecrypt documentation allows Linux user to operate only with relative (variable) paths (/dev/sda3 --> reboot --> /dev/sdc3). Due to inconstancy, paths have to be verified each time after the OS is loaded.
My bash script for mounting veracrypt volumes on Linux (shortened form):
#! /bin/bash
echo "Encrypted_1" && veracrypt --mount /dev/sdq --slot=12 --verbose && echo "Encrypted_1"
echo "Encrypted_2" && veracrypt --mount /dev/sdz3 --slot=1 --verbose && echo "Encrypted_2"
Solution?
Does anyone know whether VeraCrypt volume location can be described in absolute terms on Linux?
If it is not possible, please provide suggestions for achieving the same objective? (eg: udev? fstab?)
Erratum
mountvol.exe recognizes GUID, not UUID as was written above.
