Mysql server is failed to start suddenly, so I just uninstalled it and tried to reinstall again. But, While installing the mysql server using
#apt-get install mysql-server-5.6
I got the following error.
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
2016-02-10 23:14:20 0 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead.
2016-02-10 23:14:20 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
2016-02-10 23:14:20 0 [Note] /usr/sbin/mysqld (mysqld 5.6.28-0ubuntu0.14.04.1) starting as process 31672 ...
start: Job failed to start
invoke-rc.d: initscript mysql, action "start" failed.
dpkg: error processing package mysql-server-5.6 (--configure):
subprocess installed post-installation script returned error exit status 1
Then I saw the error message using #dmesg as follows,
[270432.510510] init: mysql main process (25270) terminated with status 2
[270432.510537] init: mysql main process ended, respawning
[270532.815355] init: mysql main process (25314) terminated with status 2
[270532.815371] init: mysql main process ended, respawning
[270633.132158] init: mysql main process (25358) terminated with status 2
[270633.132185] init: mysql main process ended, respawning
[270733.731547] init: mysql main process (25407) terminated with status 2
[270733.731606] init: mysql main process ended, respawning
[270734.215222] init: mysql main process (26314) terminated with status 2
[270734.215247] init: mysql main process ended, respawning
[270734.490352] init: mysql main process (26340) terminated with status 2
[270734.490377] init: mysql respawning too fast, stopped
[270765.881464] cc1 invoked oom-killer: gfp_mask=0x201da, order=0, oom_score_adj=0
[1982873.800674] Out of memory: Kill process 31793 (mysqld) score 546 or sacrifice child
[1982873.807943] Killed process 31793 (mysqld) total-vm:324564kB, anon-rss:282232kB, file-rss:0kB
[1982873.847242] init: mysql main process (31793) killed by KILL signal
[1982873.847261] init: mysql main process ended, respawning
[1982873.869928] init: mysql post-start process (31794) terminated with status 1
[1982875.816435] Out of memory: Kill process 31857 (mysqld) score 548 or sacrifice child
[1982875.818163] Killed process 31857 (mysqld) total-vm:390100kB, anon-rss:283084kB, file-rss:4kB
[1982875.915151] init: mysql main process (31857) killed by KILL signal
[1982875.915199] init: mysql respawning too fast, stopped
But while seeing the disk space using df -h only 3gb is used.
Filesystem Size Used Avail Use% Mounted on
/dev/vda1 20G 3.2G 16G 17% /
none 4.0K 0 4.0K 0% /sys/fs/cgroup
udev 235M 4.0K 235M 1% /dev
tmpfs 50M 356K 49M 1% /run
none 5.0M 0 5.0M 0% /run/lock
none 246M 0 246M 0% /run/shm
none 100M 0 100M 0% /run/user
So how can i come out from the error?
