I have installed Ubuntu on a separate ext4 partition. I did not create a swap partition, because I was going to create a swap file after installation. Ubuntu does not have an Internet connection, because I'm using a TP-LINK antenna.
I haven't changed any files or configuration files and I have about 50GB of storage space remaining in my Ubuntu partition.
On my first boot, I recieved the following error:
The system is running in low-graphics mode
Your screen, graphics card, and input device settings could not be detected correctly. You will need to configure these yourself.
If I attempt to login to a TTY, the session automatically closes after a short while (less than a second); but I can use the liveUSB and chroot my partition.
What do I need to do?
while the system is booting hold shift to get to the grub menu then press E
it should bring up a bunch of text that you can navigate with the arrow keys
find the line that starts with linux
it should look similar to this
linux /boot/vmlinuz-4.5.0-rc3+ root=UUID=c9932a51-0d6a-4ed0-9098-2daafc9e4500 ro quiet splash $vt_handoff
after "ro" add "nomodeset"
so the line should now look like this
linux /boot/vmlinuz-4.5.0-rc3+ root=UUID=c9932a51-0d6a-4ed0-9098-2daafc9e4500 ro nomodeset quiet splash $vt_handoff
then press F10 it may bring you to the login screen or may let you use TTY.
