By default, aptitude writes to a log file /var/log/aptitude. It produces output like this:
Aptitude 0.8.12: log report
Sun, Oct 1 2021 23:59:59 +1300
IMPORTANT: this log only lists intended actions; actions which fail
due to dpkg problems may not be completed.
Will install 6 packages, and remove 0 packages.
31.3 MB of disk space will be used
[UPGRADE] libc-dev-bin:amd64 2.31-0ubuntu9 -> 2.31-0ubuntu9.2
[UPGRADE] libc6:amd64 2.31-0ubuntu9 -> 2.31-0ubuntu9.2
[UPGRADE] libc6:i386 2.31-0ubuntu9 -> 2.31-0ubuntu9.2
[UPGRADE] libc6-dbg:amd64 2.31-0ubuntu9 -> 2.31-0ubuntu9.2
[UPGRADE] libc6-dev:amd64 2.31-0ubuntu9 -> 2.31-0ubuntu9.2
[UPGRADE] libc6-i386:amd64 2.31-0ubuntu9 -> 2.31-0ubuntu9.2
Log complete.
This shows the exact date and packages that aptitude installed. To configure this (in /etc/apt/apt.conf or in a separate file in /etc/apt/apt.conf.d/), follow the Configuration file reference in aptitude manual (also available from "Help > User's Manual" in the menu):
Option:Aptitude::Log
Default:/var/log/aptitude
Description: If this is set to a nonempty string, aptitude will log the package
installations, removals, and upgrades that it performs. If the value of
Aptitude::Log begins with a pipe character (ie, ``|''), the remainder of its
value is used as the name of a command into which the log will be piped: for
instance, |mail -s 'Aptitude install run' root will cause the log to be emailed
to root. To log to multiple files or commands, you may set this option to a list
of log targets.
