Related questions have been asked quite often, but the solutions mentioned in those questions don't seem to solve my problem.
This quesion seems to be on the right track and I use it as a general guide. This question is also related.
So, when my WiFi is on and connected and I run nmcli nm I get:
RUNNING STATE WIFI-HARDWARE WIFI WWAN-HARDWARE WWAN
running connected enabled enabled enabled enabled
If I then close the lid (sleep) and open it again (wake up) and run the command again, I get:
running disconnected disabled disabled enabled enabled
So the WIFI-HARDWARE and WIFI statusses changed from enabled to disabled.
Running man nmcli gives options I can use with nmcli nm and shows that I can switch WIFI on using nmcli nm wifi on, however if I run this it doesn't change the status of WIFI-HARDWARE or WIFI.
I think I can use a bash script and nmcli to fix this, but am not quite sure how. The original question says the following script:
#!/bin/sh
case "${1}" in
resume|thaw)
nmcli nm sleep false
esac
should be placed in /etc/pm/sleep.d, this does however not fix my problem.
