I have Ubuntu 14.04 LTS installed on a Win 7 64-bit machine via VirtualBox 5.0.14. Now I want to install a Ubuntu-based software suite called Archivematica. The instructions begin this way:
Add the archivematica/release PPA to your list of trusted repositories (if add-apt-repositories is not available you must install python-software- properties first):
sudo apt-get update
sudo apt-get install python-software-properties
sudo add-apt-repository ppa:archivematica/1.4
Firstly, I could not figure out how to add a trusted repository and don't know how to tell whether add-apt-repositories is available.
Secondly, when I enter the first sudo command and try to enter a password when prompted in the terminal window, no characters appear as I type.
Can anyone offer insight into these issues? Many thanks in advance.
Pilot6
  • 92,041
MWheel
The command that adds the repository is
If the add-apt-repository command isn't available on your system, the command won't work, and you will need to run
sudo apt-get update
and try again. However, there's no harm running those commands even if add-apt-repository is already available: apt-get will simply report that package python-software-properties is already the latest version.
For your other query, see Nothing shows up in the terminal when I type my password.
steeldriver
  • 142,475
