when trying to compile mame 0.170 I get the following error:
m1xalis@m1xalis-HP-Compaq-6830s:~$ cd .mame
m1xalis@m1xalis-HP-Compaq-6830s:~/.mame$ make
GCC 5.2.1 detected
Compiling src/osd/modules/debugger/debugqt.cpp...
../../../../../src/osd/modules/debugger/debugqt.cpp:18:34: fatal error: QtWidget
s/QApplication: No such file or directory
#include <QtWidgets/QApplication>
compilation terminated.
qtdbg_sdl.make:361: recipe for target        '../../../../linux_gcc/obj/x64/Release/qtdbg_sdl/src/osd/modules/debugger/debugqt.o' failed
make[2]: *** [../../../../linux_gcc/obj/x64/Release/qtdbg_sdl/src/osd/modules/debugger/debugqt.o] Error 1
Makefile:16: recipe for target 'qtdbg_sdl' failed
make[1]: *** [qtdbg_sdl] Error 2
makefile:1025: recipe for target 'linux_x64' failed
make: *** [linux_x64] Error 2
This is a new install and upgrade to ubuntu wily. I had previously compiled mame 0.169 on ubuntu trusty tahr using gcc 4.9 (I think). Any help/suggestions would be appreciated.
m1xalis
  • 116
I found that I needed to add this to the makefile:
QT_HOME = /usr/lib/x86_64-linux-gnu/qt5/
This was actually on Debian jessie, not Ubuntu. The directory on your system may or may not be the same. But it shouldn't be too hard to locate.
VGR
  • 160
I just added the #include line in the makefile user options and it seems to work now, compiling is in progress.
m1xalis
  • 116
-1
It Works fine for me, compiling Mame 0.172 on Linux Mint 17.3!
(with qt5-default package installed previously
sudo apt-get install qt5-default
and executing on terminal this:
export QT_SELECT=qt5
(for Qt5 version as default on system))
techraf
  • 3,316
Finin
