I have some tutorials on how to run a script at startup on ubuntu server, but it keeps failing with status=203
Here is the script.sh file i wrote in /etc/init.d :
### BEGIN INIT INFO
# Provides:            Multicraft
# Required-Start:
# Required-Stop
# Should-Start:
# Should-Stop:
# X-Start-Before:
# X-Start-After:
# Default-Start:        2 3 4 5
# Default-Stop:         0 1 6
# X-Interactive:
# Short-Description:    Multicraft daemon
# Description:          Starts the Multicraft daemon at system startup
### END INIT INFO
. /home/minecraft/multicraft/bin/multicraft -v start
exit 0
I have also run the "sudo update-rc.d script.sh defaults" command.
Can anyone please tell me what i am doing wrong?
P.S. It should be noted that when i manually run this command, the program launches and everything works as expected:
sudo /home/minecraft/multicraft/bin/multicraft -v start
Try adding Sleep into your script.
sleep 60
./home/minecraft/multicraft/bin/multicraft -v start
exit 0
OR
sleep 60
cd /home/minecraft/multicraft/bin/
sudo ./multicraft -v start
exit 0
OR
sleep 60
sudo multicraft -v start
exit 0
Please increase the sleep time if above code does not work.(if you are root user no need to use sudo)
Possible duplicate of "Startup Applications" not working
Ok i found what was the problem: I did not write #!/bin/sh in the first line of the script.sh. And this is the script that actually works:
#!/bin/sh
### BEGIN INIT INFO
# Required-Start:
# Required-Stop
### END INIT INFO
start() {
stop() {
  ./home/minecraft/multicraft/bin/multicraft -v stop
case "$1" in
  start)
    start
  stop)
    stop
esac
exit 0
Thanks for your help @editinit though.
