I'm trying to repair Ububtu 15.10 crash/lockup boots up with no icons on screen, many repairs did not sove this problem, so created a dvd install for 15.10. But after all this, It comes back with "the root filesystem on /dev/sd1 requires a manual fsck." How does one do this ? I'm not a software dev/writer etc
Asked
Active
Viewed 1.8k times
The best way is to use a Live CD/DVD to access your system (as you cannot run fsck on a mounted system). Two steps are then required:
- Boot your computer using a 'Live' CD/DVD
Open a Terminal window and run:
sudo fsck /dev/sd1
Confirm first that the drive number: sd1 is actually the correct one from your error message...
andrew.46
- 39,359
I am on Ubuntu 16.4. I faced the same issue. Any command I want to autocomplete, it comes with:
bash: cannot create temp file for here-document: Read-only file system
I was challenged by a black screen with the message
....on /dev/sd1 requires a manual fsck
I tried with sudo fsck at initramfs prompt, no chance. Then I type "help" there to get clue. Then I type sudo fsck /dev/sda1. It prompts me with lots of choices (y) for yes. I keep moving till I got the prompt initramfs. There I type exit and I got back my original set up.
David Foerster
- 36,890
- 56
- 97
- 151
user3485352
- 11
