I cannot install Mono. I have the PPA added. After doing 'sudo apt-get update' and 'sudo apt-get upgrade', I then try 'sudo apt-get install mono-complete' and I get this:
owner@Linux:~$ sudo apt-get install mono-complete
Reading package lists... Done
Building dependency tree
 mono-complete : Depends: mono-devel (= 4.2.2.30-0xamarin1) but it is not going to be installed
                 Depends: mono-4.0-service (= 4.2.2.30-0xamarin1) but it is not going to be installed
                 Depends: libmono-cil-dev (= 4.2.2.30-0xamarin1) but it is not going to be installed
owner@Linux:~$ dpkg --get-selections | grep hold
owner@Linux:~$
So nothing is held back. I even went to Software & Updates and unchecked all the default sources and the ones I added only leaving these three enabled:
http://download.mono-project.com/repo/debian wheezy main
http://download.mono-project.com/repo/debian wheezy-apache24-compat main
http://download.mono-project.com/repo/debian wheezy-libjpeg62-compat main
Another 'sudo apt-get update' and 'sudo apt-get upgrade', I then try 'sudo apt-get install mono-complete' and get the same error.
Buford T. Justice
  • 1,590
  • 14
Thanks to a comment to my question by xangua, I saw I had added a PPA that was not meant for Ubuntu. If you follow their instructions at http://www.mono-project.com/docs/getting-started/install/linux/#debian-ubuntu-and-derivatives, be sure to not accidentally add the libgdiplus PPA.
Buford T. Justice
  • 1,590
  • 14
Add the repository for mono extras (do the following as sudo)
echo "deb https://d2nlctn12v279m.cloudfront.net/repo/mono/ubuntu bionic main" | tee /etc/apt/sources.list.d/mono-extra.list
apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys CB2DE8E5
apt-get update
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Manu
